Hi Jason,
I think that is exactly what our KMviaVB.dll does. It is just a wrapper around the C++ KMotionDLL.dll that exports the functions as straight C functions.
Also the KMotion_dotNet_Interop does this also and exposes more of the C++ classes.
Have you tried those?
Message: 2362 |
Date: 11/20/2011 |
Subject: Re: Need recompiled DLL to use with LabVIEW |
Jason, The KMotion_dotNet_Interop project has the exact decorations on the export functions you are asking. They will be handled as traditional C calls without the oddly decorated functions imported on the CLR side. It will import cleanly. The KMviaVB does not have the C export decorations(and they should maybe be added) so it is probable you will have a hard time wiring up your wrappers without using a tool to discover the actual export calls. -Brad Murry From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Tom Kerekes Sent: Sunday, November 20, 2011 6:36 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] Need recompiled DLL to use with LabVIEW I think that is exactly what our KMviaVB.dll does. It is just a wrapper around the C++ KMotionDLL.dll that exports the functions as straight C functions. Also the KMotion_dotNet_Interop does this also and exposes more of the C++ classes. From: jason13086 <jason13086@...> To: DynoMotion@yahoogroups.com Sent: Sunday, November 20, 2011 5:13 PM Subject: [DynoMotion] Need recompiled DLL to use with LabVIEW Hi all,
I'm using a KFLOP controller to control a tabletop gantry positioning system. I'm using LabVIEW to control it through the serial interface, however the feedback is a little bit too slow: it takes about 0.26 seconds to query the position. I've tried increasing the baud rate to 115.2k but that doesn't appreciably reduce the time it takes to do a query.
I noticed the KMotionCNC program appears to be much faster, presumably because it's using the DLL. LabVIEW can also communicate with DLLs, however, it doesn't support DLLs compiled in C++ because of the name mangling that occurs.
The solution is to get a DLL recompiled with extern "C" statements. This will create a DLL which external programs can use more easily. There shouldn't be any issue with putting in the extern "C" statement in that would impact any other part of the existing software.
Here is more details on the extern statement: http://zone.ni.com/devzone/cda/tut/p/id/3056#toc2
Here's another small section on it: http://zone.ni.com/devzone/cda/tut/p/id/3341#toc4 http://zone.ni.com/devzone/cda/tut/p/id/3341#toc8
The C++ name decorations are needed if there are polymorphic functions. But if this DLL is composed of just simple functions, there should be no need for it.
If I get it working, I can share some labview examples here on this forum. This could be very helpful to others in the future. LabVIEW is a widely used tool.
Thanks, Jason
Message: 2364 |
Date: 11/20/2011 |
Thanks, I'll try these out and report back.
> Jason,
> -Brad Murry
> Hi Jason,
> Hi all,
> Thanks,
> Jason
Message: 2371 |
Date: 11/21/2011 |
When using the .net interop, how do I get a handle? Every function requires one.
Message: 2372 |
Date: 11/21/2011 |
Hi Jason,
I think you need to call:
extern "C" __declspec(dllexport) int __stdcall KM_dotnet_Interop_New(int *handle);
or
KM_dotnet_Interop_New(ref _InstanceHandle);
Message: 2375 |
Date: 11/21/2011 |
Are you using the Call Library Function Node?
Like here?::
http://zone.ni.com/devzone/cda/tut/p/id/4877#toc4
You should be able to browse to the KMotion_dotNet_Interop.dll, and all availble function calls should be available in the drop down.
-Brad Murry
Message: 2393 |
Date: 11/21/2011 |
I'm able to import the .net version of the dll, but when I run the int__stdcallKM_dotnet_Interop_New(int*handle); function it gives me the error message shown here:
http://i.imgur.com/HYAHz.png
"Unable to execute KMotionServer.exe"
Any idea why it's not working? This happens even after I reboot my PC. I'm calling the .net interop dll in its native directory. The labview code is here for anyone interested:
http://www.filedropper.com/dll_2
> Hi Jason,
> Â extern"C"__declspec(dllexport) int__stdcallKM_dotnet_Interop_New(int*handle);
> or
> KM_dotnet_Interop_New(ref_InstanceHandle);
> Sent: Monday, November 21, 2011 9:47 AM
> Subject: [DynoMotion] Re: Need recompiled DLL to use with LabVIEW
Message: 2395 |
Date: 11/22/2011 |
Hi Jason,
Try adding <Install Dir>\KMotion\Release which is where the KMotionServer.exe is to your Windows Path.
> Hi Jason,
> or
